Introdução
This is a Headphone Jack replacement guide for a Dell Latitude 9510 USB. Ensure the jack is fully inoperable before replacement. To replace jack, follow steps below. Use caution to ensure no further damage to hardware.
O que você precisa
Flip the device so that the base plate is facing you.
Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
Use a Phillips #0 screwdriver to remove the four 3.5 mm screws.
