Ir para o conteúdo principal
Dell Latitude 9510 Fan Replacement
O que você precisa
  1. Dell Latitude 9510 Fan Replacement, Base Panel: passo 1, imagem 1 %32
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Fan Replacement: passo 2, imagem 1 %32
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Fan Replacement, Speakers: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  4. Dell Latitude 9510 Fan Replacement: passo 4, imagem 1 %32
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
  5. Dell Latitude 9510 Fan Replacement, Fan: passo 5, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws securing the fan.
  6. Dell Latitude 9510 Fan Replacement: passo 6, imagem 1 %32
    • Place your fingernails behind the plastic tabs on the speaker's motherboard connector, then pull directly backwards, toward the wires, until the connector releases from its port.
    • Lift the fan up and out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 145
