Ir para o conteúdo principal
Dell Latitude 9510 Battery Replacement
O que você precisa
  1. Dell Latitude 9510 Battery Replacement, Base Panel: passo 1, imagem 1 %32
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Battery Replacement: passo 2, imagem 1 %32
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Battery Replacement, Battery: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
  4. Dell Latitude 9510 Battery Replacement: passo 4, imagem 1 %32
    • Place a spudger behind a plastic tab on either side of the plug, then "walk" the connector out of its socket by gently pushing the plug toward the cables, alternating sides, until the connector releases.
    • Lift the battery up and out.
Conclusão
David Cauley
Membro desde: 02/10/22
85 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 47
Duração total: 763
