Ir para o conteúdo principal
Dell Latitude 9410 2-in-1 Fan Replacement
O que você precisa
  1. Dell Latitude 9410 2-in-1 Fan Replacement, Base Panel: passo 1, imagem 1 %32
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Fan Replacement: passo 2, imagem 1 %32 Dell Latitude 9410 2-in-1 Fan Replacement: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Fan Replacement: passo 3, imagem 1 %32 Dell Latitude 9410 2-in-1 Fan Replacement: passo 3, imagem 2 %32 Dell Latitude 9410 2-in-1 Fan Replacement: passo 3, imagem 3 %32
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Fan Replacement, Fan: passo 4, imagem 1 %32 Dell Latitude 9410 2-in-1 Fan Replacement, Fan: passo 4, imagem 2 %32 Dell Latitude 9410 2-in-1 Fan Replacement, Fan: passo 4, imagem 3 %32
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 Fan Replacement: passo 5, imagem 1 %32 Dell Latitude 9410 2-in-1 Fan Replacement: passo 5, imagem 2 %32
    • Use a Philips #00 screwdriver to remove the two 2 mm screws.
    • After the screws are removed, lift off the silver bracket, toward the top left of the fan.
  6. Dell Latitude 9410 2-in-1 Fan Replacement: passo 6, imagem 1 %32 Dell Latitude 9410 2-in-1 Fan Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Grip both sides of the fan connector plug with tweezers, and pull directly backwards, toward the cables, until the plug disconnects.
  7. Dell Latitude 9410 2-in-1 Fan Replacement: passo 7, imagem 1 %32 Dell Latitude 9410 2-in-1 Fan Replacement: passo 7, imagem 2 %32
    • Lift the fan up and out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 412
