Ir para o conteúdo principal
Dell Latitude 7420 Battery Replacement
O que você precisa
  1. Dell Latitude 7420 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Latitude 7420 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
  2. Dell Latitude 7420 Battery Replacement: passo 2, imagem 1 %32 Dell Latitude 7420 Battery Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
  3. Dell Latitude 7420 Battery Replacement: passo 3, imagem 1 %32 Dell Latitude 7420 Battery Replacement: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
  4. Dell Latitude 7420 Battery Replacement: passo 4, imagem 1 %32
    • Disconnect the battery from the motherboard by gently pulling out the connector.
  5. Dell Latitude 7420 Battery Replacement: passo 5, imagem 1 %32 Dell Latitude 7420 Battery Replacement: passo 5, imagem 2 %32
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
Conclusão
4 outras pessoas executaram este guia.
Hong Lee
Membro desde: 05/11/21
208 Reputação
Autoria de 1 guia
Um comentário
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 72
Últimos 30 dias: 331
Duração total: 10,361
