Ir para o conteúdo principal
Dell Latitude 7390 SSD Replacement
O que você precisa
  1. Dell Latitude 7390 SSD Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 SSD Replacement: passo 2, imagem 1 %32 Dell Latitude 7390 SSD Replacement: passo 2, imagem 2 %32 Dell Latitude 7390 SSD Replacement: passo 2, imagem 3 %32
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 SSD Replacement: passo 3, imagem 1 %32
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 SSD Replacement: passo 4, imagem 1 %32 Dell Latitude 7390 SSD Replacement: passo 4, imagem 2 %32
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 SSD Replacement: passo 5, imagem 1 %32
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 SSD Replacement, Battery: passo 6, imagem 1 %32
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 SSD Replacement: passo 7, imagem 1 %32 Dell Latitude 7390 SSD Replacement: passo 7, imagem 2 %32 Dell Latitude 7390 SSD Replacement: passo 7, imagem 3 %32
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 SSD Replacement: passo 8, imagem 1 %32
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 SSD Replacement, Solid State Drive (SSD): passo 9, imagem 1 %32
    • Using a Phillips screwdriver, remove the 6 mm screw from the SSD cover.
  10. Dell Latitude 7390 SSD Replacement: passo 10, imagem 1 %32
    • Remove the SSD card from under the silver plate.
Conclusão
Thomas Pryor
Membro desde: 02/22/22
86 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 1-4, Hunter Spring 2022 Membro de Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 63
Duração total: 2,968
