Ir para o conteúdo principal
Dell Latitude 5480 Speakers Replacement
O que você precisa
  1. Dell Latitude 5480 Speakers Replacement, Lower Case: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Speakers Replacement: passo 2, imagem 1 %32 Dell Latitude 5480 Speakers Replacement: passo 2, imagem 2 %32 Dell Latitude 5480 Speakers Replacement: passo 2, imagem 3 %32
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Speakers Replacement, Battery: passo 3, imagem 1 %32 Dell Latitude 5480 Speakers Replacement, Battery: passo 3, imagem 2 %32
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Speakers Replacement: passo 4, imagem 1 %32 Dell Latitude 5480 Speakers Replacement: passo 4, imagem 2 %32 Dell Latitude 5480 Speakers Replacement: passo 4, imagem 3 %32
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: passo 5, imagem 1 %32 Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: passo 5, imagem 2 %32
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  6. Dell Latitude 5480 Speakers Replacement, Speakers: passo 6, imagem 1 %32 Dell Latitude 5480 Speakers Replacement, Speakers: passo 6, imagem 2 %32 Dell Latitude 5480 Speakers Replacement, Speakers: passo 6, imagem 3 %32
    • Flip the motherboard to view the speaker cable connection on the underside.
    • Flip up the speaker cable ZIF locking flap.
    • Disconnect the touchpad ribbon cable.
  7. Dell Latitude 5480 Speakers Replacement: passo 7, imagem 1 %32 Dell Latitude 5480 Speakers Replacement: passo 7, imagem 2 %32 Dell Latitude 5480 Speakers Replacement: passo 7, imagem 3 %32
    • Disconnect the speaker cable by pulling it directly out of its motherboard port.
    • Do not pull on the wires.
  8. Dell Latitude 5480 Speakers Replacement: passo 8, imagem 1 %32 Dell Latitude 5480 Speakers Replacement: passo 8, imagem 2 %32 Dell Latitude 5480 Speakers Replacement: passo 8, imagem 3 %32
    • Carefully unseat the wire between the two speakers from the clips.
    • Lift the speakers up and out of the chassis.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 69
