Ir para o conteúdo principal
Dell Latitude 5480 Power Jack Replacement
O que você precisa
  1. Dell Latitude 5480 Power Jack Replacement, Lower Case: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Power Jack Replacement: passo 2, imagem 1 %32 Dell Latitude 5480 Power Jack Replacement: passo 2, imagem 2 %32 Dell Latitude 5480 Power Jack Replacement: passo 2, imagem 3 %32
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: passo 3, imagem 1 %32 Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: passo 3, imagem 2 %32
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  4. Dell Latitude 5480 Power Jack Replacement, Power Jack: passo 4, imagem 1 %32 Dell Latitude 5480 Power Jack Replacement, Power Jack: passo 4, imagem 2 %32 Dell Latitude 5480 Power Jack Replacement, Power Jack: passo 4, imagem 3 %32
    • Unscrew the right 3.7 mm screw that secures the fabric flap and the right side of the charging port bracket.
    • Carefully lift the flap out of the way of the left charging port bracket screw.
    • Unscrew the second 3.7 mm screw on the left side of the charging port bracket.
  5. Dell Latitude 5480 Power Jack Replacement: passo 5, imagem 1 %32 Dell Latitude 5480 Power Jack Replacement: passo 5, imagem 2 %32 Dell Latitude 5480 Power Jack Replacement: passo 5, imagem 3 %32
    • Remove the metal bracket that secures the charging port.
    • Keep the fabric flap tucked out of the way.
    • Use the pointed edge of a spudger to push the charging port motherboard connector directly out of its port.
  6. Dell Latitude 5480 Power Jack Replacement: passo 6, imagem 1 %32
    • Lift the entire charging port assembly up and out of the chassis.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 72
