Ir para o conteúdo principal
Dell Latitude 5480 Display Replacement
O que você precisa
  1. Dell Latitude 5480 Display Replacement, Lower Case: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Display Replacement: passo 2, imagem 1 %32 Dell Latitude 5480 Display Replacement: passo 2, imagem 2 %32 Dell Latitude 5480 Display Replacement: passo 2, imagem 3 %32
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Display Replacement, Battery: passo 3, imagem 1 %32 Dell Latitude 5480 Display Replacement, Battery: passo 3, imagem 2 %32
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Display Replacement: passo 4, imagem 1 %32 Dell Latitude 5480 Display Replacement: passo 4, imagem 2 %32 Dell Latitude 5480 Display Replacement: passo 4, imagem 3 %32
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Display Replacement, Display: passo 5, imagem 1 %32 Dell Latitude 5480 Display Replacement, Display: passo 5, imagem 2 %32 Dell Latitude 5480 Display Replacement, Display: passo 5, imagem 3 %32
    • Insert a plastic card between the bezel and the display.
    • Slide the plastic card beneath the entire bezel to sever the adhesive that secures the bezel.
    • Lift the bezel off of the display.
  6. Dell Latitude 5480 Display Replacement: passo 6, imagem 1 %32 Dell Latitude 5480 Display Replacement: passo 6, imagem 2 %32 Dell Latitude 5480 Display Replacement: passo 6, imagem 3 %32
    • Remove the four 5.6 mm Phillips head screws, one at each corner, to release the display assembly.
    • Gently lift away the display panel and set it on top of the keyboard.
    • Take care not to strain the display assemble cable.
  7. Dell Latitude 5480 Display Replacement: passo 7, imagem 1 %32 Dell Latitude 5480 Display Replacement: passo 7, imagem 2 %32 Dell Latitude 5480 Display Replacement: passo 7, imagem 3 %32
    • On the bottom of the back of the display panel, remove the tape that secures the cable connecting the screen to the base of the computer.
    • Flip up the display cable locking bar.
    • Disconnect the display connector.
    • Remove the display.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 33
Duração total: 70
