Ir para o conteúdo principal
Dell Latitude 3520 System Fan Replacement
O que você precisa
  1. Dell Latitude 3520 System Fan Replacement, Remove MicroSD-card: passo 1, imagem 1 %32
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 System Fan Replacement, Bottom Case: passo 2, imagem 1 %32 Dell Latitude 3520 System Fan Replacement, Bottom Case: passo 2, imagem 2 %32 Dell Latitude 3520 System Fan Replacement, Bottom Case: passo 2, imagem 3 %32
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 System Fan Replacement, Battery: passo 3, imagem 1 %32
    • Slide the metal above the connector on the battery to unlock.
  4. Dell Latitude 3520 System Fan Replacement: passo 4, imagem 1 %32 Dell Latitude 3520 System Fan Replacement: passo 4, imagem 2 %32
    • Peel the adhesive tapes and the battery cable.
  5. Dell Latitude 3520 System Fan Replacement: passo 5, imagem 1 %32
    • Disconnect the battery cable from the connector on the system board.
  6. Dell Latitude 3520 System Fan Replacement: passo 6, imagem 1 %32 Dell Latitude 3520 System Fan Replacement: passo 6, imagem 2 %32
    • Remove the three 2mm Phillip #0 screws that secure the battery in place.
  7. Dell Latitude 3520 System Fan Replacement: passo 7, imagem 1 %32
    • Lift and remove the battery.
  8. Dell Latitude 3520 System Fan Replacement, System Fan: passo 8, imagem 1 %32
    • Disconnect the system fan cable from the connector on the system board.
  9. Dell Latitude 3520 System Fan Replacement: passo 9, imagem 1 %32
    • Remove the two 2mm Phillips #0 screws that secure the system fan.
  10. Dell Latitude 3520 System Fan Replacement: passo 10, imagem 1 %32
    • Lift and remove the system fan.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 117
