Introdução
Utilize this step-by-step manual for swapping out the screen on your Dell Latitude 3520 laptop. If you are experiencing frequent screen blackouts or visibility issues, it might be the right moment for a replacement.
O que você precisa
Push the microSD-card to eject it from the slot.
Remove the microSD-card from the computer.
Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
Carefully lift and remove the base cover.
Remove the 2mm Phillip #0 screw that secures the WLAN card bracket to the WLAN card on the system board.
Lift and remove the WLAN card bracket from the WLAN card that secures the two antenna cables.
Disconnect the antenna cables from the connectors on the WLAN card.
Disconnect and remove the WLAN card from the WLAN card slot.
