Introdução
Please refer to this manual for instructions on replacing your computer's battery. Ensure you have the necessary tools on hand, including a plastic scribe and a Phillips 0 driver.
By following a few straightforward steps, you can effectively address battery-related problems and restore your laptop's optimal performance. Given the crucial role of the laptop battery, it is imperative to promptly tackle any battery issues.
O que você precisa
Push the microSD-card to eject it from the slot.
Remove the microSD-card from the computer.
Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
Carefully lift and remove the base cover.
