Ir para o conteúdo principal
Dell Latitude 3500 WLAN Card Replacement
O que você precisa
  1. Dell Latitude 3500 WLAN Card Replacement, Remove screws: passo 1, imagem 1 %32
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 WLAN Card Replacement, Separate bottom cover and palmrest: passo 2, imagem 1 %32
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 WLAN Card Replacement, Disconnect and Remove Battery: passo 3, imagem 1 %32
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 WLAN Card Replacement, Unscrew Bracket: passo 4, imagem 1 %32
    • Holds down card and keeps antenna in place
  5. Dell Latitude 3500 WLAN Card Replacement, Disconnect Antennas: passo 5, imagem 1 %32
    • Carefully remove the two antennas from their slots.
    • The card should slide right out for easy replacement.
Conclusão
Jake
Membro desde: 03/08/23
1.336 Reputação
Autoria de 14 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 106
