Ir para o conteúdo principal
Dell Latitude 3500 VGA Board Replacement
O que você precisa
  1. Dell Latitude 3500 VGA Board Replacement, Remove screws: passo 1, imagem 1 %32
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 VGA Board Replacement, Separate bottom cover and palmrest: passo 2, imagem 1 %32
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 VGA Board Replacement, Disconnect and Remove Battery: passo 3, imagem 1 %32
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 VGA Board Replacement, Disconnect Surrounding Connections from System Fan: passo 4, imagem 1 %32
    • Unplug the fan header
    • Unplug the VGA board cable
    • Unplug the LCD cable
  5. Dell Latitude 3500 VGA Board Replacement, Remove Fan Screws: passo 5, imagem 1 %32
    • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
  6. Dell Latitude 3500 VGA Board Replacement, Disconnect VGA Board: passo 6, imagem 1 %32
    • Pull straight up from the motherboard
  7. Dell Latitude 3500 VGA Board Replacement, Remove Screws: passo 7, imagem 1 %32
    • 2 screws
    • Board can now be safely removed from device
Conclusão
Jake
Membro desde: 03/08/23
1.336 Reputação
Autoria de 14 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 51
