Ir para o conteúdo principal
Dell Latitude 3400 Screen Assembly Replacement
O que você precisa
  1. Dell Latitude 3400  Screen Assembly Replacement, Remove Bottom Cover: passo 1, imagem 1 %32
    • Begin by removing all 9 screws from the bottom of the laptop. These screws are safety screws so once they are loose, they wont fall out.
    • To remove bottom cover, pull up on the back of the cover to loosen snaps. Once they have become unsnapped, pull up on the right side and detach then the left side and detach. Once this is done, the lid should be able to pull off. Take care to pull it from around the ports.
  2. Dell Latitude 3400  Screen Assembly Replacement, Disconnect Battery: passo 2, imagem 1 %32
    • This is an important step! Disconnect the battery to avoid the risk of electric shock.
  3. Dell Latitude 3400  Screen Assembly Replacement, Disconnect Display: passo 3, imagem 1 %32
    • Pull back any tape and gently lift the plastic tab holding the display ribbon in place. Gently pull the ribbon from the socket.
  4. Dell Latitude 3400  Screen Assembly Replacement, Remove Wireless Card: passo 4, imagem 1 %32 Dell Latitude 3400  Screen Assembly Replacement, Remove Wireless Card: passo 4, imagem 2 %32 Dell Latitude 3400  Screen Assembly Replacement, Remove Wireless Card: passo 4, imagem 3 %32
    • Remove the screw holding the card and plastic guard in place.
    • Gently remove disconnect both the black and white wires
    • Remove Card
  5. Dell Latitude 3400  Screen Assembly Replacement, Release Hinges: passo 5, imagem 1 %32 Dell Latitude 3400  Screen Assembly Replacement, Release Hinges: passo 5, imagem 2 %32 Dell Latitude 3400  Screen Assembly Replacement, Release Hinges: passo 5, imagem 3 %32
    • Remove the screws in both the right and left hinges.
    • Lift hinges up and pull the lid out from under laptop.
  6. Dell Latitude 3400  Screen Assembly Replacement, Finished: passo 6, imagem 1 %32
    • If everything has gone smoothly, you will have been able to separate the screen assembly from the base.
Conclusão
Uma outra pessoa concluiu este guia.
Ethan Jones
Membro desde: 07/16/18
542 Reputação
Autoria de 2 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 2,907
