Ir para o conteúdo principal
Dell Latitude 3380 Motherboard Replacement
O que você precisa
  1. Dell Latitude 3380 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Motherboard Replacement: passo 2, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 2, imagem 2 %32
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement, Motherboard: passo 3, imagem 2 %32 Dell Latitude 3380 Motherboard Replacement, Motherboard: passo 3, imagem 3 %32
    • Remove the four 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
    • Disconnect the battery cable by gently pulling it out.
    • Remove the battery.
  4. Dell Latitude 3380 Motherboard Replacement: passo 4, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 4, imagem 2 %32 Dell Latitude 3380 Motherboard Replacement: passo 4, imagem 3 %32
    • Remove the 3 mm screw from the WLAN card using a Phillips #0 screwdriver.
    • Disconnect and remove the WLAN card.
  5. Dell Latitude 3380 Motherboard Replacement: passo 5, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 5, imagem 2 %32 Dell Latitude 3380 Motherboard Replacement: passo 5, imagem 3 %32
    • Disconnect the audio cable.
    • Remove the entire audio card piece.
  6. Dell Latitude 3380 Motherboard Replacement: passo 6, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 6, imagem 2 %32 Dell Latitude 3380 Motherboard Replacement: passo 6, imagem 3 %32
    • Remove the two 5 mm screws from the fan using a Phillips #0 screwdriver.
    • Loosen the four captive screws on the heatsink using a Phillips #0 screwdriver.
    • Remove the heatsink from the motherboard.
  7. Dell Latitude 3380 Motherboard Replacement: passo 7, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, loosen the power connector from the fan to the motherboard, fully disconnecting the fan.
  8. Dell Latitude 3380 Motherboard Replacement: passo 8, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 8, imagem 2 %32 Dell Latitude 3380 Motherboard Replacement: passo 8, imagem 3 %32
    • Using a Phillips #0 screwdriver, unscrew and remove this metal plate.
    • Gently disconnect the cable under the metal plate.
  9. Dell Latitude 3380 Motherboard Replacement: passo 9, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 9, imagem 2 %32
    • Disconnect the battery power cable.
  10. Dell Latitude 3380 Motherboard Replacement: passo 10, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 10, imagem 2 %32
    • Disconnect the power cable that connects to the charging port.
  11. Dell Latitude 3380 Motherboard Replacement: passo 11, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 11, imagem 2 %32
    • Disconnect the touchpad cable.
  12. Dell Latitude 3380 Motherboard Replacement: passo 12, imagem 1 %32 Dell Latitude 3380 Motherboard Replacement: passo 12, imagem 2 %32
    • Remove the five screws from the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 301
