Introdução
This guide will aid in the replacement of the Dell Latitude 3380 front camera.
The front camera performs as an accessory for many applications on the laptop, including video calls and meetings, recording presentations, and taking exams. There are many reasons why your camera might need replacing, including hardware failure from impacts, outdated software, and even malware. Make sure to check that your laptop is updated to the most current software. If the issue remains, then your issue is not outdated software, and in return requires this process of replacement.
O que você precisa
Turn the laptop over so that the back is facing up.
Remove the nine 3 mm screws with a Phillips #0 screwdriver.
