Ir para o conteúdo principal
Dell Latitude 3190 Power Switch Board Replacement
O que você precisa
  1. Dell Latitude 3190 Power Switch Board Replacement, Base Cover: passo 1, imagem 1 %32 Dell Latitude 3190 Power Switch Board Replacement, Base Cover: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Power Switch Board Replacement: passo 2, imagem 1 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 2, imagem 2 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 2, imagem 3 %32
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Power Switch Board Replacement, Battery: passo 3, imagem 1 %32
    • Locate the battery.
  4. Dell Latitude 3190 Power Switch Board Replacement: passo 4, imagem 1 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 4, imagem 2 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 4, imagem 3 %32
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Power Switch Board Replacement: passo 5, imagem 1 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 5, imagem 2 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 5, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Power Switch Board Replacement: passo 6, imagem 1 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 6, imagem 2 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 6, imagem 3 %32
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: passo 7, imagem 1 %32 Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: passo 7, imagem 2 %32
    • Disconnect the power switch cable from the motherboard.
  8. Dell Latitude 3190 Power Switch Board Replacement: passo 8, imagem 1 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 8, imagem 2 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 8, imagem 3 %32
    • Remove the two 3 mm screws that secure the power switch board on the computer.
  9. Dell Latitude 3190 Power Switch Board Replacement: passo 9, imagem 1 %32 Dell Latitude 3190 Power Switch Board Replacement: passo 9, imagem 2 %32
    • Lift the power switchboard away from the computer.
Conclusão
Haley Smith
Membro desde: 09/01/21
305 Reputação
Autoria de 2 guias
Equipe
Gateway, Team 1-5, Saknee Fall 2021 Membro de Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 343
