Ir para o conteúdo principal
Dell Latitude 3190 Keyboard Replacement
O que você precisa
  1. Dell Latitude 3190 Keyboard Replacement, Base Cover: passo 1, imagem 1 %32 Dell Latitude 3190 Keyboard Replacement, Base Cover: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Keyboard Replacement: passo 2, imagem 1 %32 Dell Latitude 3190 Keyboard Replacement: passo 2, imagem 2 %32 Dell Latitude 3190 Keyboard Replacement: passo 2, imagem 3 %32
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Keyboard Replacement, Battery: passo 3, imagem 1 %32
    • Locate the battery.
  4. Dell Latitude 3190 Keyboard Replacement: passo 4, imagem 1 %32 Dell Latitude 3190 Keyboard Replacement: passo 4, imagem 2 %32 Dell Latitude 3190 Keyboard Replacement: passo 4, imagem 3 %32
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Keyboard Replacement: passo 5, imagem 1 %32 Dell Latitude 3190 Keyboard Replacement: passo 5, imagem 2 %32 Dell Latitude 3190 Keyboard Replacement: passo 5, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Keyboard Replacement: passo 6, imagem 1 %32 Dell Latitude 3190 Keyboard Replacement: passo 6, imagem 2 %32 Dell Latitude 3190 Keyboard Replacement: passo 6, imagem 3 %32
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Keyboard Replacement, Keyboard: passo 7, imagem 1 %32 Dell Latitude 3190 Keyboard Replacement, Keyboard: passo 7, imagem 2 %32
    • Use the spudger to release the small black tab locking down the connector by lightly pushing up on it.
    • Disconnect the keyboard cable from the connector on the system board.
  8. Dell Latitude 3190 Keyboard Replacement: passo 8, imagem 1 %32 Dell Latitude 3190 Keyboard Replacement: passo 8, imagem 2 %32
    • Hold down the laptop securely while pushing into the two release holes using a spudger.
    • You may need to push harder than you think, you will feel it release.
  9. Dell Latitude 3190 Keyboard Replacement: passo 9, imagem 1 %32 Dell Latitude 3190 Keyboard Replacement: passo 9, imagem 2 %32 Dell Latitude 3190 Keyboard Replacement: passo 9, imagem 3 %32
    • Turn the laptop over, so the keyboard is facing up
    • Pry the bottom of the keyboard using a spudger to the release the keyboard.
    • Slide the keyboard outwards, away from the computer, and lift the keyboard away from the computer.
Conclusão
Haley Smith
Membro desde: 09/01/21
308 Reputação
Autoria de 2 guias
Equipe
Gateway, Team 1-5, Saknee Fall 2021 Membro de Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Membros
Autoria de 9 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 27
Ao todo: 1,334
