Introdução
If you need to replace the base cover or access the internals of your Dell Latitude 3190 laptop, follow this guide.
Prior to beginning this repair, power off your laptop and unplug it from the charging cable.
O que você precisa
Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
Quase terminado!
Conclusão
