Ir para o conteúdo principal
Dell Latitude 3189 Power Jack Replacement
O que você precisa
  1. Dell Latitude 3189 Power Jack Replacement, Lower Case: passo 1, imagem 1 %32 Dell Latitude 3189 Power Jack Replacement, Lower Case: passo 1, imagem 2 %32
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Power Jack Replacement: passo 2, imagem 1 %32 Dell Latitude 3189 Power Jack Replacement: passo 2, imagem 2 %32 Dell Latitude 3189 Power Jack Replacement: passo 2, imagem 3 %32
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Power Jack Replacement: passo 3, imagem 1 %32 Dell Latitude 3189 Power Jack Replacement: passo 3, imagem 2 %32
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Power Jack Replacement: passo 4, imagem 1 %32 Dell Latitude 3189 Power Jack Replacement: passo 4, imagem 2 %32 Dell Latitude 3189 Power Jack Replacement: passo 4, imagem 3 %32
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Power Jack Replacement, Power Jack: passo 5, imagem 1 %32
    • Use a spudger to push the charging port connector directly out of its motherboard port.
    • The charging port is located in the top-right corner of the device, near the hinge.
  6. Dell Latitude 3189 Power Jack Replacement: passo 6, imagem 1 %32 Dell Latitude 3189 Power Jack Replacement: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the two 3.3 mm screws that secure the power jack to the chassis.
  7. Dell Latitude 3189 Power Jack Replacement: passo 7, imagem 1 %32
    • Slide and lift the power connector port away from the computer.
Conclusão
Bryan Pratt
Membro desde: 02/14/24
601 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 55
