Introdução
This guide will provide a step by step guide to remove the battery from the tablet. This is necessary for a device which has a faulty, broken, or a worn out battery.
O que você precisa
Place tablet face-down on flat surface.
Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
4 outras pessoas executaram este guia.
Um comentário
I found that the down volume control was jammed by the case. So be careful with the reassembly around the volume control.
