Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
O que você precisa
Remove the two screws that secure the hard-drive assembly to the system board.
Slide the hard-drive assembly to disconnect it from the system-board connector.
Remove the four screws that secure the hard drive to the hard-drive bracket.
Replace the four screws that secure the hard drive to the hard-drive bracket.
Slide the hard-drive assembly to connect it to the system-board connector.
Replace the two screws that secure the hard-drive assembly to the system-board.
3 outras pessoas executaram este guia.
