Ir para o conteúdo principal
Dell Inspiron n5110 Battery Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Shut down the computer and turn it over.
  1. Dell Inspiron n5110 Battery Replacement, Sliding the Latch: passo 2, imagem 1 %32
    • Slide the battery release latch and the battery lock latch to the unlock positions.
  2. Dell Inspiron n5110 Battery Replacement, Lifting the Battery: passo 3, imagem 1 %32
    • Slide and lift the battery out of the battery bay.
  3. Dell Inspiron n5110 Battery Replacement, Sliding the Battery: passo 4, imagem 1 %32
    • Slide the NEW battery into the battery bay until it clicks into place.
  4. Dell Inspiron n5110 Battery Replacement, Sliding the Battery Latch: passo 5, imagem 1 %32
    • Slide the battery lock latch to the lock position.
Linha de Chegada
4 outras pessoas executaram este guia.
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,188
