Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Passo 1 Battery
Cuidado: as etapas de 1 a 3 são provenientes de um guia marcado como em andamento.
Flip your laptop over to view the bottom and locate the two locks.
Flip the laptop right side up. Open the laptop.
Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
Gently flip the data cable latch away from the data cable with flat side of spudger.
Lift the cable up and out.
When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
Close the lid, flip the laptop bottom side up with the battery at the top.
Remove the 11 screws holding the upper case to the lower case.
10 outras pessoas executaram este guia.
