Ir para o conteúdo principal
Dell Inspiron n5050 Optical Drive Replacement
O que você precisa
  1. Dell Inspiron n5050 Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 Optical Drive Replacement: passo 2, imagem 1 %32
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 Optical Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron n5050 Optical Drive Replacement: passo 3, imagem 2 %32
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 Optical Drive Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron n5050 Optical Drive Replacement, Keyboard: passo 4, imagem 2 %32
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 Optical Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron n5050 Optical Drive Replacement: passo 5, imagem 2 %32 Dell Inspiron n5050 Optical Drive Replacement: passo 5, imagem 3 %32
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
  6. Dell Inspiron n5050 Optical Drive Replacement, Optical Drive screw: passo 6, imagem 1 %32 Dell Inspiron n5050 Optical Drive Replacement, Optical Drive screw: passo 6, imagem 2 %32
    • Unscrew the screw next to the wireless card.
  7. Dell Inspiron n5050 Optical Drive Replacement, Unseat optical drive: passo 7, imagem 1 %32
    • Stand laptop on its side.
    • Use the flat end of the spudger to unseat the optical drive.
    • It works best with a twisting motion of the spudger.
Conclusão
5 outras pessoas executaram este guia.
Tyler
Membro desde: 06/19/12
4.920 Reputação
Autoria de 16 guias
Equipe
TechForce Membro de TechForce
Business
Membros da 2
Autoria de 25 guias
2 comentários
I am curious why the guide notes that you need to remove the keyboard ribbon? Removing and installing that cable weakens it and could damage it. I was able to remove the drive without taking out the ribbon cable; I just flipped the keyboard out of the way.
afterhourspc - Responder
it says you don’t need
F2w -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 3,299
