Ir para o conteúdo principal
Dell Inspiron n5050 Keyboard Replacement
O que você precisa
  1. Cuidado: as etapas de 1 a 3 são provenientes de um guia marcado como em andamento.
    Dell Inspiron n5050 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 Keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron n5050 Keyboard Replacement: passo 3, imagem 2 %32
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron n5050 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 Keyboard Replacement: passo 5, imagem 1 %32 Dell Inspiron n5050 Keyboard Replacement: passo 5, imagem 2 %32 Dell Inspiron n5050 Keyboard Replacement: passo 5, imagem 3 %32
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
    What do I do is i broke the cable retainer wings and the black thing?
    Wezley Joao Ferreira - Responder
    If the connector on the motherboard is still attached and only the clip is broken you can try and find a new clip, or perhaps tape the keyboard in place with electrical tape.
    Tyler - Responder
    I didn’t need to disconnect and remove the cable. I simply set the keyboard gently to the side. This gave me full access to the two RAM module slots for replacement. Hopefully this will make the procedure easier.
    Clemmitt Sigler - Responder
Conclusão
4 outras pessoas executaram este guia.
Tyler
Membro desde: 06/19/12
4.920 Reputação
Autoria de 16 guias
Equipe
TechForce Membro de TechForce
Business
Membros da 2
Autoria de 25 guias
4 comentários
dis has realy helped me sir... love you!
jovialcom - Responder
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
https://youtu.be/3c5P0pJgckg
mohamed - Responder
Here’s a video guide to replacing the keyboard on this (or similar) laptop: https://www.youtube.com/watch?v=6T3xgkC-...
Paul Freeman-Powell - Responder
My keyboard is not have a clips what i do?
BurIsm - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 9,823
