Ir para o conteúdo principal
Dell Inspiron One 2020 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: passo 1, imagem 2 %32 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: passo 1, imagem 3 %32
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Dell Inspiron One 2020 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron One 2020 Hard Drive Replacement: passo 2, imagem 2 %32 Dell Inspiron One 2020 Hard Drive Replacement: passo 2, imagem 3 %32
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Dell Inspiron One 2020 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron One 2020 Hard Drive Replacement: passo 3, imagem 2 %32 Dell Inspiron One 2020 Hard Drive Replacement: passo 3, imagem 3 %32
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
  4. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Remove the three screws that hold the hard drive cage to the chassis.
  5. Dell Inspiron One 2020 Hard Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron One 2020 Hard Drive Replacement: passo 5, imagem 2 %32
    • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
    • There isn't much slack in these cables, so don't slide the hard drive cage to far.
    • The power and SATA cables are connected together. On most other computers, these connectors are separate.
    • Lift the hard drive cage out.
  6. Dell Inspiron One 2020 Hard Drive Replacement: passo 6, imagem 1 %32 Dell Inspiron One 2020 Hard Drive Replacement: passo 6, imagem 2 %32 Dell Inspiron One 2020 Hard Drive Replacement: passo 6, imagem 3 %32
    • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
Conclusão
35 outras pessoas executaram este guia.
Tyler
Membro desde: 06/19/12
4.920 Reputação
Autoria de 16 guias
Equipe
TechForce Membro de TechForce
Business
Membros da 2
Autoria de 25 guias
3 comentários
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - Responder
Good Job, short and sweet and easy to follow
schmidtrg - Responder
Really useful information thank you.
Jessie Colon - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 78
Duração total: 35,723
