Ir para o conteúdo principal
Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement
O que você precisa
Vídeo de Apresentação
  1. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement, WiFi Half Mini PCI card: passo 1, imagem 1 %32 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement, WiFi Half Mini PCI card: passo 1, imagem 2 %32 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement, WiFi Half Mini PCI card: passo 1, imagem 3 %32
    • Switch off the laptop and remove the battery.
    • The keyboard is held by 4x locking clips.
    • By using cutter, carefully lift up the one side of the keyboard and start opening the locking clips.
  2. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: passo 2, imagem 1 %32 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: passo 2, imagem 2 %32 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: passo 2, imagem 3 %32
    • Disconnect the keyboard cable and remove the keyboard.
    • Remove the access door screw and the access door
    • Remove the screw securing the optical drive, and remove the optical drive
  3. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: passo 3, imagem 1 %32 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: passo 3, imagem 2 %32 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: passo 3, imagem 3 %32
    • Remove all the screws
    • Pry the upper plastic casing off of the laptop
  4. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: passo 4, imagem 1 %32 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: passo 4, imagem 2 %32 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: passo 4, imagem 3 %32
Conclusão
4 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
192.056 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.525 guias
2 comentários
Great, cogent step by step. You alleviated the need to watch a video while including all of the key steps. Nicely done. I replaced a hard drive last year and I would have preferred this format.
Robert Gemkow - Responder
Hi, do you know if there is a whitelist for wifi adapters in this notebook?
Artem White - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 17
Duração total: 7,360
