Introdução
Before disassembling this device further, have a screwdriver and a plastic opening tool nearby. This section of the guide involves removing the keyboard, so make sure you carefully pull the keyboard cable to prevent damaging it.
O que você precisa
Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
Aren't there 13 screws in that picture, aside from the two hard drive screws, bringing the total to 15?
Flip over and open the laptop to view the keyboard.
Use a plastic opening tool to press down on four clips, one by one.
Press down on the clips and pull the tool towards you to pry the keyboard loose.
The plastic opening tool is really ideal for this step. Especially use of one with a bit of a hook to it, so you may lift up the keyboard without pulling upon the individual keys. The keys can pop off, which is undesirable.
Without the pry tool, I ended up using the edge of a clean plastic take-out container to both press down the tab while the lip provided the hook action needed to lift up the keyboard itself. Used a popsicle stick temporarily to brace it as the remaining clips were undone.
Remove the keyboard carefully.
Flip the keyboard over to find the keyboard cable.
Pull the cable labeled "UP" out to disconnect it from the laptop.
To remove the keyboard flexible flat cable, there is a dark grey strip securing the cable, (visible in the detailed photo). This grey plastic strip secures the cable, and is undone by lifting gently from the long edge adjacent to the UP label. It has 2 delicate pivot points left and right of the visible conductors in the white plastic connector.
If you just grab and yank the flexible flat cable, this piece will likely just pop off, but can be re-seated provided it did not break.
Unscrew the two palmrest screws.
Lift the two, blue palmrest cables up and out of their sockets.
Lift the entire surface (palmrest casing) to expose the motherboard underneath.
11 outras pessoas executaram este guia.
How many gb hard drive can I install on Inspiron n5050
Anguiano pro - Responder
