Ir para o conteúdo principal
Dell Inspiron N5050 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron N5050 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip your laptop over to view the bottom and the two locks.
  2. Dell Inspiron N5050 Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron N5050 Hard Drive Replacement: passo 3, imagem 2 %32
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 Hard Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron N5050 Hard Drive Replacement: passo 5, imagem 2 %32
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 Hard Drive Replacement: passo 6, imagem 1 %32 Dell Inspiron N5050 Hard Drive Replacement: passo 6, imagem 2 %32 Dell Inspiron N5050 Hard Drive Replacement: passo 6, imagem 3 %32
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 Hard Drive Replacement: passo 7, imagem 1 %32 Dell Inspiron N5050 Hard Drive Replacement: passo 7, imagem 2 %32 Dell Inspiron N5050 Hard Drive Replacement: passo 7, imagem 3 %32
    • Unscrew the two palmrest screws.
    • Lift the two, blue palmrest cables up and out of their sockets.
  8. Dell Inspiron N5050 Hard Drive Replacement: passo 8, imagem 1 %32 Dell Inspiron N5050 Hard Drive Replacement: passo 8, imagem 2 %32
    • Lift the entire surface (palmrest casing) to expose the motherboard underneath.
  9. Dell Inspiron N5050 Hard Drive Replacement: passo 9, imagem 1 %32
    • Slide the hard drive right and up to remove it from the laptop.
Conclusão
11 outras pessoas executaram este guia.
4Comentários do guia
Thanks again. This guide was made straightforward and clear.
jason acn - Responder
Thanks you - The clear instructions make this guide easy to follow.
Jay - Responder
wouldnt turn on after i re-assembled it
Taemon Coolz - Responder
Sehr gute Arbeit
pouchman - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 7,088
