Ir para o conteúdo principal
Dell Inspiron N5010 Hard Drive Replacement
O que você precisa
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron N5010 Hard Drive Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the four screws that secure the hard-drive assembly.
  2. Dell Inspiron N5010 Hard Drive Replacement, Lifting the Hard Drive Assembly: passo 3, imagem 1 %32
    • Turn the computer over and lift the hard-drive assembly out of the hard-drive bay to disconnect the hard-drive assembly from the connector on the system board.
  3. Dell Inspiron N5010 Hard Drive Replacement, Disconnect the Interposer: passo 4, imagem 1 %32
    • Pull the interposer to disconnect it from the hard drive.
  4. Dell Inspiron N5010 Hard Drive Replacement, Connect the Interposer: passo 5, imagem 1 %32
    • Connect the interposer to the NEW hard drive.
  5. Dell Inspiron N5010 Hard Drive Replacement, Align the Hard Drive Assembly: passo 6, imagem 1 %32
    • Align the hard-drive assembly with the connector on the system board and press the hard-drive assembly into the hard-drive bay until it is fully seated.
  6. Dell Inspiron N5010 Hard Drive Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Turn the computer over and replace the four screws that secure the hard-drive assembly.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 1,886
