Ir para o conteúdo principal
Dell Inspiron N5010 Battery Replacement
O que você precisa
  1. Dell Inspiron N5010 Battery Replacement, Turn Over the Computer: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Shut down the computer and turn it over.
  2. Dell Inspiron N5010 Battery Replacement, Sliding the Battery Latch: passo 2, imagem 1 %32
    • Slide the battery lock latch to the unlock position.
  3. Dell Inspiron N5010 Battery Replacement, Sliding the Battery Latch: passo 3, imagem 1 %32
    • Slide the battery release latch to the side.
  4. Dell Inspiron N5010 Battery Replacement, Lifting the Battery: passo 4, imagem 1 %32
    • Slide and lift the battery out of the battery bay.
  5. Dell Inspiron N5010 Battery Replacement, Align the Tabs: passo 5, imagem 1 %32
    • Align the tabs on the NEW battery with the slots on the battery bay.
  6. Dell Inspiron N5010 Battery Replacement, Sliding the Battery: passo 6, imagem 1 %32
    • Slide the battery into the battery bay until it clicks into place.
  7. Dell Inspiron N5010 Battery Replacement, Sliding the Lock Latch: passo 7, imagem 1 %32
    • Slide the battery lock latch to the lock position.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 1,194
