Ir para o conteúdo principal
Dell Inspiron N4110 Screen Replacement
O que você precisa
  1. Dell Inspiron N4110 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Screen Replacement: passo 2, imagem 1 %32
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Screen Replacement: passo 3, imagem 1 %32
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Screen Replacement, Screen: passo 4, imagem 1 %32 Dell Inspiron N4110 Screen Replacement, Screen: passo 4, imagem 2 %32 Dell Inspiron N4110 Screen Replacement, Screen: passo 4, imagem 3 %32
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Dell Inspiron N4110 Screen Replacement: passo 5, imagem 1 %32 Dell Inspiron N4110 Screen Replacement: passo 5, imagem 2 %32
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Dell Inspiron N4110 Screen Replacement: passo 6, imagem 1 %32 Dell Inspiron N4110 Screen Replacement: passo 6, imagem 2 %32
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Dell Inspiron N4110 Screen Replacement: passo 7, imagem 1 %32 Dell Inspiron N4110 Screen Replacement: passo 7, imagem 2 %32 Dell Inspiron N4110 Screen Replacement: passo 7, imagem 3 %32
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Dell Inspiron N4110 Screen Replacement: passo 8, imagem 1 %32 Dell Inspiron N4110 Screen Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Dell Inspiron N4110 Screen Replacement: passo 9, imagem 1 %32 Dell Inspiron N4110 Screen Replacement: passo 9, imagem 2 %32 Dell Inspiron N4110 Screen Replacement: passo 9, imagem 3 %32
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. Dell Inspiron N4110 Screen Replacement: passo 10, imagem 1 %32
    • The screen can now be fully removed from the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Abigail Keith
Membro desde: 03/20/18
505 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S5-G1, Peak Spring 2018 Membro de UMass Dartmouth, Team S5-G1, Peak Spring 2018
UMASSD-PEAK-S18S5G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 1,248
