Ir para o conteúdo principal
Dell Inspiron N4110 RAM Replacement
O que você precisa
  1. Dell Inspiron N4110 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 RAM Replacement: passo 2, imagem 1 %32
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 RAM Replacement: passo 3, imagem 1 %32
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 RAM Replacement, RAM: passo 4, imagem 1 %32 Dell Inspiron N4110 RAM Replacement, RAM: passo 4, imagem 2 %32
    • Locate and unscrew the one 2.5x5 mm screw on the cover.
    • The screw does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  5. Dell Inspiron N4110 RAM Replacement: passo 5, imagem 1 %32 Dell Inspiron N4110 RAM Replacement: passo 5, imagem 2 %32
    • Remove RAM cover from the laptop.
  6. Dell Inspiron N4110 RAM Replacement: passo 6, imagem 1 %32 Dell Inspiron N4110 RAM Replacement: passo 6, imagem 2 %32
    • Use your fingers to separate the two metal clips from the RAM.
    • The RAM will lift up when properly separated. Do not force the RAM out of the clips.
  7. Dell Inspiron N4110 RAM Replacement: passo 7, imagem 1 %32
    • Remove the RAM from the computer.
    • Be careful as to not touch the metal on the bottom of the RAM. This can cause damage.
    • The RAM should be placed on a non-conductive surface.
Conclusão
Olivia
Membro desde: 03/20/18
773 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S5-G1, Peak Spring 2018 Membro de UMass Dartmouth, Team S5-G1, Peak Spring 2018
UMASSD-PEAK-S18S5G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 765
