Introdução
This guide helps replace the fan if the computer is overheating. This will require a fan replacement.
O que você precisa
Locate the battery on the underside of the laptop.
Push the two battery clips following the direction of the arrows.
Flip the computer over, and open the laptop.
Use a plastic opening tool to begin to remove the keyboard.
Use your hands to finish separating the keyboard from the laptop.
Disconnect the ribbon cable over the screw to reveal it. Flip up the latch and pull gently on the ribbon to remove it from the connector.
Unscrew the 2.5x5 mm screw from the fan.
3 outras pessoas executaram este guia.
