Ir para o conteúdo principal
Dell Inspiron N4110 Fan Replacement
O que você precisa
  1. Dell Inspiron N4110 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Fan Replacement: passo 2, imagem 1 %32
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Fan Replacement: passo 3, imagem 1 %32
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Fan Replacement, Fan: passo 4, imagem 1 %32 Dell Inspiron N4110 Fan Replacement, Fan: passo 4, imagem 2 %32
    • Remove the 10 2.5x5 mm screws from the base of the laptop.
  5. Dell Inspiron N4110 Fan Replacement: passo 5, imagem 1 %32
    • Unscrew the final 2.5x5 mm screw attached to the cover.
    • This screw is "captive" and does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  6. Dell Inspiron N4110 Fan Replacement: passo 6, imagem 1 %32 Dell Inspiron N4110 Fan Replacement: passo 6, imagem 2 %32
    • Remove the cover from the laptop.
  7. Dell Inspiron N4110 Fan Replacement: passo 7, imagem 1 %32 Dell Inspiron N4110 Fan Replacement: passo 7, imagem 2 %32
    • Unscrew the 2.5x5 mm screw inside the RAM compartment.
  8. Dell Inspiron N4110 Fan Replacement: passo 8, imagem 1 %32 Dell Inspiron N4110 Fan Replacement: passo 8, imagem 2 %32
    • Remove the disk drive from the side of the computer.
    • There is no need to press the button, the drive will come out.
  9. Dell Inspiron N4110 Fan Replacement: passo 9, imagem 1 %32 Dell Inspiron N4110 Fan Replacement: passo 9, imagem 2 %32
    • Unscrew the two 2x3 mm screws inside the disk drive compartment.
  10. Dell Inspiron N4110 Fan Replacement: passo 10, imagem 1 %32 Dell Inspiron N4110 Fan Replacement: passo 10, imagem 2 %32 Dell Inspiron N4110 Fan Replacement: passo 10, imagem 3 %32
    • Flip the computer over, and open the laptop.
    • Use a plastic opening tool to begin to remove the keyboard.
    • Use your hands to finish separating the keyboard from the laptop.
    • This can be a bit challenging, but it will come loose.
  11. Dell Inspiron N4110 Fan Replacement: passo 11, imagem 1 %32
    • Lift the black clip from the tan connection for the keyboard.
    • Pull the the connection away from the clip.
    • Move the keyboard away from the laptop.
    • With the keyboard removed, consider this opportunity to more freely clean it out with some compressed air.
  12. Dell Inspiron N4110 Fan Replacement: passo 12, imagem 1 %32
    • Lift the black clips from the tan connections for all 3 locations marked.
    • Remove the connections from the clips.
  13. Dell Inspiron N4110 Fan Replacement: passo 13, imagem 1 %32
    • Unscrew the five 2.5x5 mm screws.
  14. Dell Inspiron N4110 Fan Replacement: passo 14, imagem 1 %32 Dell Inspiron N4110 Fan Replacement: passo 14, imagem 2 %32
    • Use plastic opening tools to remove base cover.
    • Use your hands to fully remove cover from the base.
    • This may be difficult, but it is possible.
  15. Dell Inspiron N4110 Fan Replacement: passo 15, imagem 1 %32
    • Disconnect the two cables that connect the speaker and the fan.
    • These can just be pulled out, they do not have clips.
  16. Dell Inspiron N4110 Fan Replacement: passo 16, imagem 1 %32
    • Disconnect the ribbon cable over the screw to reveal it. Flip up the latch and pull gently on the ribbon to remove it from the connector.
    • Unscrew the 2.5x5 mm screw from the fan.
  17. Dell Inspiron N4110 Fan Replacement: passo 17, imagem 1 %32 Dell Inspiron N4110 Fan Replacement: passo 17, imagem 2 %32
    • Pull up and remove the fan from the laptop.
Conclusão
3 outras pessoas executaram este guia.
Olivia
Membro desde: 03/20/18
752 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S5-G1, Peak Spring 2018 Membro de UMass Dartmouth, Team S5-G1, Peak Spring 2018
UMASSD-PEAK-S18S5G1
Membros da 3
Autoria de 6 guias
Um comentário
Wow! What a great guide. Really made the job easier. Thanks!!!
swtilden - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 1,233
