Ir para o conteúdo principal
Dell Inspiron N4010 Top Cover Replacement
O que você precisa
  1. Dell Inspiron N4010 Top Cover Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Top Cover Replacement: passo 2, imagem 1 %32 Dell Inspiron N4010 Top Cover Replacement: passo 2, imagem 2 %32
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Top Cover Replacement: passo 3, imagem 1 %32
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Top Cover Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron N4010 Top Cover Replacement, Keyboard: passo 4, imagem 2 %32 Dell Inspiron N4010 Top Cover Replacement, Keyboard: passo 4, imagem 3 %32
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Top Cover Replacement: passo 5, imagem 1 %32
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Top Cover Replacement: passo 7, imagem 1 %32 Dell Inspiron N4010 Top Cover Replacement: passo 7, imagem 2 %32
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Top Cover Replacement: passo 8, imagem 1 %32 Dell Inspiron N4010 Top Cover Replacement: passo 8, imagem 2 %32
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Top Cover Replacement: passo 9, imagem 1 %32 Dell Inspiron N4010 Top Cover Replacement: passo 9, imagem 2 %32
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
  9. Dell Inspiron N4010 Top Cover Replacement, Top Cover: passo 10, imagem 1 %32 Dell Inspiron N4010 Top Cover Replacement, Top Cover: passo 10, imagem 2 %32
    • Remove the indicated 5.7mm screws.
    • Remove the smaller 3mm screws from underneath the battery compartment.
  10. Dell Inspiron N4010 Top Cover Replacement: passo 11, imagem 1 %32 Dell Inspiron N4010 Top Cover Replacement: passo 11, imagem 2 %32
    • With a plastic spudger, pry away the silver top cover from the black casing.
    • Move the tool to the right and left along the seams to fully disconnect the cover.
  11. Dell Inspiron N4010 Top Cover Replacement: passo 12, imagem 1 %32
    • Disconnect the indicated ribbon cables underneath where the keyboard sits.
  12. Dell Inspiron N4010 Top Cover Replacement: passo 13, imagem 1 %32
    • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
Conclusão
Equipe
USF Tampa, Team S13-G5, Boczar Fall 2017 Membro de USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 745
