Introdução
Replacing the speakers can fix possible hardware-related sound issues
O que você precisa
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Remove the indicated 5.7mm screws.
Remove the smaller 3mm screws from underneath the battery compartment.
Peel back the yellow tape to expose the ribbon connector.
Unplug the ribbon cable from the motherboard.
Unscrew the two screws on the right hand speaker with the #0 Phillips Head.
Unplug the speaker connector from the motherboard.
