Introdução
Removal and replacement of the palm rest assembly gives access to many components. The palm rest assembly also includes the touchpad. This guide is often a prerequisite to replacing many internal components.
O que você precisa
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Remove the indicated 5.7mm screws.
Remove the smaller 3mm screws from underneath the battery compartment.
Quase terminado!
Conclusão
