Ir para o conteúdo principal
Dell Inspiron N4010 Keyboard Replacement
O que você precisa
  1. Dell Inspiron N4010 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron N4010 Keyboard Replacement: passo 2, imagem 2 %32
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Keyboard Replacement: passo 3, imagem 1 %32
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron N4010 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Dell Inspiron N4010 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Keyboard Replacement: passo 5, imagem 1 %32
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Keyboard Replacement: passo 7, imagem 1 %32 Dell Inspiron N4010 Keyboard Replacement: passo 7, imagem 2 %32
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Keyboard Replacement: passo 8, imagem 1 %32 Dell Inspiron N4010 Keyboard Replacement: passo 8, imagem 2 %32
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Keyboard Replacement: passo 9, imagem 1 %32 Dell Inspiron N4010 Keyboard Replacement: passo 9, imagem 2 %32
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
Conclusão
Equipe
USF Tampa, Team S13-G5, Boczar Fall 2017 Membro de USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
Membros da 5
Autoria de 9 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 14
Duração total: 988
