Ir para o conteúdo principal
Dell Inspiron Mini 1012: Keyboard Replacement
O que você precisa
  1. Dell Inspiron Mini 1012: Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the battery
  2. Dell Inspiron Mini 1012: Keyboard Replacement: passo 2, imagem 1 %32
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Dell Inspiron Mini 1012: Keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron Mini 1012: Keyboard Replacement: passo 3, imagem 2 %32
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  4. Dell Inspiron Mini 1012: Keyboard Replacement: passo 4, imagem 1 %32
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Linha de Chegada
4 outras pessoas executaram este guia.
Marie K Bordley
Membro desde: 09/30/14
241 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team 1-1, Buehl Fall 2014 Membro de Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
Membros da 4
Autoria de 4 guias
Um comentário
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 3,295
