Ir para o conteúdo principal
Dell Inspiron Mini 1012 Screen Replacement
O que você precisa
  1. Dell Inspiron Mini 1012 Screen Replacement, Screen: passo 1, imagem 1 %32 Dell Inspiron Mini 1012 Screen Replacement, Screen: passo 1, imagem 2 %32 Dell Inspiron Mini 1012 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
    • Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
    • Carefully remove the plastic casing from the device.
  2. Dell Inspiron Mini 1012 Screen Replacement: passo 2, imagem 1 %32 Dell Inspiron Mini 1012 Screen Replacement: passo 2, imagem 2 %32 Dell Inspiron Mini 1012 Screen Replacement: passo 2, imagem 3 %32
    • Remove the four screws on each corner of the screen. Then remove the screws located on the side of the screen.
    • Carefully unplug the ribbon on the back of the screen.
  3. Dell Inspiron Mini 1012 Screen Replacement: passo 3, imagem 1 %32 Dell Inspiron Mini 1012 Screen Replacement: passo 3, imagem 2 %32 Dell Inspiron Mini 1012 Screen Replacement: passo 3, imagem 3 %32
    • Place the new screen onto the device and plug the ribbon in.
    • Replace the screws on the side of the screen.
  4. Dell Inspiron Mini 1012 Screen Replacement: passo 4, imagem 1 %32 Dell Inspiron Mini 1012 Screen Replacement: passo 4, imagem 2 %32 Dell Inspiron Mini 1012 Screen Replacement: passo 4, imagem 3 %32
    • Snap on the plastic screen cover and replace the two screws and the rubber pieces at the bottom of the screen.
    • Turn the computer over and put the battery back in.
Conclusão
To reassemble your device, follow guide instructions.
sabinabarajas
Membro desde: 10/17/15
372 Reputação
Autoria de 3 guias
Equipe
Gateway, Team 2-2, Kuhn Fall 2015 Membro de Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Membro
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 1,346
