Ir para o conteúdo principal
Dell Inspiron Mini 10 Palm Rest Replacement
O que você precisa
  1. Dell Inspiron Mini 10 Palm Rest Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Replacement: passo 2, imagem 1 %32
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Replacement, Palm Rest: passo 3, imagem 1 %32
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Palm Rest Replacement: passo 4, imagem 1 %32
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
Conclusão
Bariso Shuba
Membro desde: 10/26/16
270 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team 1-4, Rose Fall 2016 Membro de UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 301
