Ir para o conteúdo principal
Dell Inspiron Mini 10 Keyboard Replacement
O que você precisa
  1. Dell Inspiron Mini 10 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Keyboard Replacement: passo 4, imagem 1 %32
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Keyboard Replacement: passo 5, imagem 1 %32 Dell Inspiron Mini 10 Keyboard Replacement: passo 5, imagem 2 %32
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Keyboard Replacement: passo 6, imagem 1 %32 Dell Inspiron Mini 10 Keyboard Replacement: passo 6, imagem 2 %32
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
Conclusão
Equipe
UW Tacoma, Team 1-4, Rose Fall 2016 Membro de UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 1,309
