Ir para o conteúdo principal
Dell Inspiron Mini 10 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron Mini 10 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Hard Drive Replacement, Palm Rest: passo 3, imagem 1 %32
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Hard Drive Replacement: passo 4, imagem 1 %32
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Hard Drive Replacement, Keyboard: passo 5, imagem 1 %32
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  6. Dell Inspiron Mini 10 Hard Drive Replacement: passo 6, imagem 1 %32
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  7. Dell Inspiron Mini 10 Hard Drive Replacement: passo 7, imagem 1 %32 Dell Inspiron Mini 10 Hard Drive Replacement: passo 7, imagem 2 %32
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  8. Dell Inspiron Mini 10 Hard Drive Replacement: passo 8, imagem 1 %32 Dell Inspiron Mini 10 Hard Drive Replacement: passo 8, imagem 2 %32
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  9. Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: passo 9, imagem 1 %32 Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: passo 9, imagem 2 %32
    • Remove the single 8mm screw attaching the hard-drive cage to the body of the device.
  10. Dell Inspiron Mini 10 Hard Drive Replacement: passo 10, imagem 1 %32 Dell Inspiron Mini 10 Hard Drive Replacement: passo 10, imagem 2 %32
    • Pull on the black tab and slide the hard-drive cage toward the USB port until is comes free.
  11. Dell Inspiron Mini 10 Hard Drive Replacement: passo 11, imagem 1 %32
    • Unscrew the four 3mm screws, two on each side of the drive, and slide the drive free from the cage.
Conclusão
3 outras pessoas executaram este guia.
Bariso Shuba
Membro desde: 10/26/16
270 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team 1-4, Rose Fall 2016 Membro de UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 47
Duração total: 7,117
