Introdução
Use this guide to replace the fan in your Dell Inspiron M531R-5535 laptop.
The fan is an essential component for preventing the computer from overheating. The fan allows the computer hardware to cool off and make the computer more smoothly.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
O que você precisa
Unscrew the Phillips #1 screw.
Pull the white connector out to disconnect the cables from the motherboard.
Pull up on gold connectors (MHF4) to disconnect the cables connecting the WLAN card.
Pull up on the white flap and pull out the strip to disconnect the strip from the motherboard.
