Ir para o conteúdo principal
Dell Inspiron M531R-5535 Fan Replacement
O que você precisa
  1. Dell Inspiron M531R-5535 Fan Replacement, Fan: passo 1, imagem 1 %32 Dell Inspiron M531R-5535 Fan Replacement, Fan: passo 1, imagem 2 %32 Dell Inspiron M531R-5535 Fan Replacement, Fan: passo 1, imagem 3 %32
    • Flip the laptop over and unlock the battery.
    • Lift up to remove the battery.
  2. Dell Inspiron M531R-5535 Fan Replacement: passo 2, imagem 1 %32 Dell Inspiron M531R-5535 Fan Replacement: passo 2, imagem 2 %32
    • Loosen the two Phillips #1 screws to remove the tray.
    • The screws stay in the tray.
  3. Dell Inspiron M531R-5535 Fan Replacement: passo 3, imagem 1 %32 Dell Inspiron M531R-5535 Fan Replacement: passo 3, imagem 2 %32
    • Unscrew the 3.6mm Phillips #1 screw.
    • Slide the CD Drive out.
  4. Dell Inspiron M531R-5535 Fan Replacement: passo 4, imagem 1 %32 Dell Inspiron M531R-5535 Fan Replacement: passo 4, imagem 2 %32
    • Unscrew nine 5.7mm Phillips #1 screws.
    • Unscrew three 5.6mm Phillips #1 screws
    • The three 5.6mm Phillips #1 screws are thinner.
    • Then flip the laptop and open it to see the keyboard.
  5. Dell Inspiron M531R-5535 Fan Replacement: passo 5, imagem 1 %32 Dell Inspiron M531R-5535 Fan Replacement: passo 5, imagem 2 %32
    • Use a nylon spudger or plastic opening tool to press into the highlighted keyboard latches.
  6. Dell Inspiron M531R-5535 Fan Replacement: passo 6, imagem 1 %32 Dell Inspiron M531R-5535 Fan Replacement: passo 6, imagem 2 %32 Dell Inspiron M531R-5535 Fan Replacement: passo 6, imagem 3 %32
    • Lift up the keyboard.
    • Lift up on the black ZIF tab and pull the keyboard ribbon cable free.
  7. Dell Inspiron M531R-5535 Fan Replacement: passo 7, imagem 1 %32 Dell Inspiron M531R-5535 Fan Replacement: passo 7, imagem 2 %32
    • Unscrew the five 5.6mm Phillips #1 screws.
    • Unscrew the two 3.6mm Phillips #1 screws.
  8. Dell Inspiron M531R-5535 Fan Replacement: passo 8, imagem 1 %32 Dell Inspiron M531R-5535 Fan Replacement: passo 8, imagem 2 %32
    • Disconnect all highlighted cables.
  9. Dell Inspiron M531R-5535 Fan Replacement: passo 9, imagem 1 %32 Dell Inspiron M531R-5535 Fan Replacement: passo 9, imagem 2 %32
    • Using an opening tool, carefully pry open the case from the side.
  10. Dell Inspiron M531R-5535 Fan Replacement: passo 10, imagem 1 %32
    • Unscrew the Phillips #1 screw.
    • Pull the white connector out to disconnect the cables from the motherboard.
    • Pull up on gold connectors (MHF4) to disconnect the cables connecting the WLAN card.
    • Pull up on the white flap and pull out the strip to disconnect the strip from the motherboard.
  11. Dell Inspiron M531R-5535 Fan Replacement: passo 11, imagem 1 %32
    • Flip the motherboard over.
    • Pull the white connector out to disconnect the fan.
    • Lift the fan to remove it from the motherboard.
Conclusão
Tony Chen
Membro desde: 09/26/22
310 Reputação
Autoria de 2 guias
Equipe
CSU Los Angeles, Team 6-5, Adachi Fall 2022 Membro de CSU Los Angeles, Team 6-5, Adachi Fall 2022
CSULA-ADACHI-F22S6G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 225
