Ir para o conteúdo principal
Dell Inspiron M5110 Palmrest Replacement
O que você precisa
  1. Dell Inspiron M5110 Palmrest Replacement, Battery: passo 1, imagem 1 %32
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Palmrest Replacement: passo 2, imagem 1 %32
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Palmrest Replacement: passo 3, imagem 1 %32
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Palmrest Replacement, Keyboard: passo 4, imagem 1 %32
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Palmrest Replacement: passo 5, imagem 1 %32
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Palmrest Replacement: passo 6, imagem 1 %32
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Palmrest Replacement: passo 7, imagem 1 %32
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Palmrest Replacement: passo 8, imagem 1 %32
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Palmrest Replacement: passo 9, imagem 1 %32
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
  10. Dell Inspiron M5110 Palmrest Replacement, Palmrest: passo 10, imagem 1 %32
    • Turn the computer over and remove the six screws that secure the palmrest assembly
  11. Dell Inspiron M5110 Palmrest Replacement: passo 11, imagem 1 %32
    • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
  12. Dell Inspiron M5110 Palmrest Replacement: passo 12, imagem 1 %32 Dell Inspiron M5110 Palmrest Replacement: passo 12, imagem 2 %32
    • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
  13. Dell Inspiron M5110 Palmrest Replacement: passo 13, imagem 1 %32 Dell Inspiron M5110 Palmrest Replacement: passo 13, imagem 2 %32
    • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
Conclusão
Uma outra pessoa concluiu este guia.
Larain
Membro desde: 10/26/16
387 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-3, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-3, Catania Fall 2016
UMASSD-CATANIA-F16S4G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 174
