Ir para o conteúdo principal
Dell Inspiron M5110 Keyboard Replacement
O que você precisa
  1. Dell Inspiron M5110 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Keyboard Replacement: passo 3, imagem 1 %32
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Keyboard Replacement: passo 5, imagem 1 %32
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Keyboard Replacement: passo 6, imagem 1 %32
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Keyboard Replacement: passo 7, imagem 1 %32
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Keyboard Replacement: passo 8, imagem 1 %32
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Keyboard Replacement: passo 9, imagem 1 %32
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Cody Flynn
Membro desde: 10/18/16
331 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 4-3, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-3, Catania Fall 2016
UMASSD-CATANIA-F16S4G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 270
